Drivers message center
Old Jun 5, 2018 | 02:08 PM
04ss-owner's Avatar
Default Drivers message center
In the drivers message center in the dash it says security....now I have to replace my key fob already but will that take care of the message....or what else could it be
Old Jun 5, 2018 | 02:13 PM
Nah, your fob won't fix it. You have an issue with either the ignition cylinder, wiring to the cylinder, or the BCM. Ignition cylinder issue is most likely.
Old Jun 22, 2018 | 11:14 PM
04ss-owner's Avatar
Wondering if it failing to turn over a few times before starting would be a clear sign of ignition cylinder
Old Jun 23, 2018 | 03:14 PM
04ss-owner's Avatar
If the ignition takes a few tries every now and then before actually turning the car over and starting, would that confirm it's the ignition, or is that another problem in itself, and where could I find a BCM
Old Jun 24, 2018 | 10:47 PM
The security system in these cars require three devices to be synced up: The PCM, BCM and chip on the ignition lock cylinder (NOT the ignition switch).
The BCM is located near the eBrake pedal and requires programming with a GM Tech II.
Best thing I could recommend, is if you can get it to a shop (most likely a dealership) that has a GM TechII, check for any security codes stored. If the security system activated, there has to be a code for it.
dbaldwin
Jul 2, 2014 12:32 AM
Amanda Rodgers
May 1, 2014 03:59 PM
Holly19
Nov 18, 2011 06:14 PM
big green dog
Jan 7, 2010 11:18 PM
jeff2425
Dec 9, 2009 07:05 AM
