Driver side window won't roll up
It's supposed to thunderstorm later this morning, so of course the drivers side window on my 03 MC won't roll up now. This happened once before and after trying to roll it up for a half hour the button finally worked again, but that was on a weekend and not while i was at work. Anyone have any ideas other than to keep fiddling with the switch as i pray that it goes up? is this a common problem and is it expensive to get fixed?
Hi RJO, Sounds like a bad switch or it needs to be cleaned.
Check back on your thread question to see what our expert tech member's post on your problem..
Until then ? , you may want to check out the below..Good Luck
1998 monte carlo automobile driver's side window won't go up ...
answers.yahoo.com › ... › Cars & Transportation › Maintenance & Repairs - Cached
4 answers - Jan 3, 2008
1998 monte carlo automobile driver's side window won't go up? ... does it make noise when you try to roll it up? Or is it just nothing? ...
Get more discussion results
<LI class="g knavi">
Replace Power Window Switch - How To Information | eHow.com
www.ehow.com › Car Repair & Maintenance - Cached
My Window Clicks But Won't Go Up & Down on My 2002 Mercury Sable ... Power windows in cars should roll up and down freely and quietly with the flip of .... Replacing your 1998 Chevrolet Silverado's driver side door window is a long and difficult task. .... The Monte Carlo continued to exist as a two-door coupe until it was ...
Thanks. Are switches expensive? I took the actual black plastic cap off the switch to show the switch i assume underneath it. Thought maybe that'd help me push differently or harder to maybe get it to go up, but that didnt help so i put the cover back on the switch. Tried for 15 minutes that time and still no go. I'll give it another shot at lunch.
My window also has a mind of its own my temporary solution to you is to push the button while pulling the window up, the higher you get it hopefully the dryer your car is, unless the window is completely down inside the car
Jester_20
08-24-2014 02:29 PM
gtpshawty
09-13-2013 03:29 AM
tekboi
12-06-2010 06:25 PM
