Custom Radio Help
Old Aug 17, 2011 | 09:07 PM
BlackRainSS's Avatar
Default Custom Radio Help
If I put in a custom radio in will I be able to access all my key fob change oil light and tire pressure etc features. Has anyone tried it? I wanna put in a custom stero but want to be able to turn off those lights if they come on. Is there any way to get them turned off if the stereo dosent work.
Old Aug 17, 2011 | 10:14 PM
Wilco's Avatar
There are simple instructions here in the forum for resetting oil and tire pressure lights, your issue will be with everything else once you replace the stock radio. What I did was to set everything on the stock radio the way I wanted before I replaced it.
Old Aug 18, 2011 | 03:26 PM
Whats do you mean by "your issue will be with everything else once you replace the stock radio"???? I have all the lights reset but say the change oil comes on how would i turn it off?
Old Aug 18, 2011 | 03:40 PM
To do the oil: Turn the key to ON, pump the gas pedal all the way down and back 3 times in 5 seconds.
To do the tire pressure: Turn the key to ON, pull the light **** halfway and push it back in 3 times in 5 seconds.
Old Aug 18, 2011 | 07:44 PM
Thanks Chibi thats what I was looking for
Old Aug 18, 2011 | 09:30 PM
you can always relocate the stock one.
Old Aug 18, 2011 | 10:40 PM
I don't really want the stock one my LS has sort of become a project, I'm going to experiment with doing things on it and see how they go before doing a lot to the SS. But the SS will keep the stock stero may get kicker or rockford 6x9s but thats all for sound system.
Old Aug 19, 2011 | 08:13 AM
What Trewyn is saying, is there are relocation harnesses that you can add to your car. You could run it to the trunk, and just leave the harness in a spot that is hidden.
If you ever need to access something through the radio, you just undo the hiding spot, and plug the radio in. Then you can easily do whatever is needed (without affecting your sound system)
But those harnesses aren't cheap.
Jaymoung
Mar 31, 2015 10:20 PM
guysnydr
Sep 18, 2013 07:43 PM
dustybird3
Apr 8, 2011 10:10 PM
ralphtrent
FWD Tech Guides '95-'07
Nov 28, 2010 04:35 AM
jasonm56
Apr 9, 2007 01:21 AM
