car wont start
Old Nov 29, 2014 | 01:07 PM
avendo's Avatar
Default car wont start
Held in the radio button and tried to get the menu up and now the car wont do anything,says cal error on radio...what the hell....
Old Nov 29, 2014 | 01:25 PM
avendo's Avatar
battery just died for some reason,what would do that? car was just running for 20 min..
Old Nov 29, 2014 | 07:07 PM
owens91's Avatar
if the car was running for 20 mins and nothing happened when you tried to start it again i would suspect the alternator, it should of charged the battery within that time
Old Nov 29, 2014 | 10:16 PM
nitehawkjcb's Avatar
How old is the battery?
Old Nov 30, 2014 | 09:24 AM
avendo's Avatar
Was charging over 14 volts...
Old Nov 30, 2014 | 10:36 AM
03SSLE's Avatar
If the alternator is showing an output of 14 volts at the battery then it is ok. I would suspect a loose/dirty connection at the battery itself, or the ground cable where it bolts to the stud on the transaxle. If they are all clean and tight then I would check the battery for a bad cell. Something else to consider is you cannot charge a battery to full capacity from the alternator. It needs to be put on a battery charger. The alternator will put a 'surface charge' on the battery, but that does not indicate the true voltage or amperage of the battery. The vehicle will start a few times with the surface charge, but after sitting for a while it won't start.
schoentges16
Feb 27, 2021 06:43 AM
bigdomvegas
Oct 21, 2017 07:54 PM
BrandonStebing
Jul 25, 2014 11:03 AM
Knightwolf702
May 14, 2014 07:13 PM
midnitetill6
Jul 6, 2005 06:35 PM
