Broken A/C. NOOOOOOO!!!!!!
Old Jul 17, 2012 | 04:08 PM
mstrmysterious63's Avatar
Default Broken A/C. NOOOOOOO!!!!!!
with a daily average of 105 degrees, this just wont do.
im pretty sure its just the fan. i can hear it click and the sound of something running, which is what i always hear right before the air comes out (it always takes a sec. i guess because its electric and not vacuum? or so iv been told) but the air never came out
i guess thats the compressor running.
luckily it rained while i was at work, so by the time i went to leave, it had cooled off outside and the ride home wasnt bad... but this has got to be fixed ASAP... and id really like to save some $$ and do it myself (if possible)
Old Jul 17, 2012 | 05:03 PM
DE02Carlo's Avatar
Does the fan blow at all?
I guess you can open the hood and see if the compressor is engaging and while being carful feel the line to the evaporator (bigger line) it should be cold. The return line to the condenser (smaller line) should be hot.
Old Jul 17, 2012 | 05:36 PM
I was going to ask if it was all the fan speeds or just the first two. The resistors on the fan speed selector tend to go. Had to replace the resistor for the first two speeds on my 99 Grand Am a couple times. Have you checked the obvious? Fuses, relays, etc?
Old Jul 17, 2012 | 06:35 PM
Had a smiliar problem on my dads gmc envoy. Compressor would enguage but no fan no matter what you did. Fix was to replace the resistor pack.
Old Jul 17, 2012 | 06:59 PM
aussiek2000's Avatar
Like others have said, blower motor resister. Pretty common on most GMs.
Old Jul 18, 2012 | 10:02 AM
It was all speeds. I was actually getting cold air. I cracked a window to see if any air would come through, and it did.
But, it worked fine on my way to work today. So I'm thinking its probably a bad connection somewhere.
Old Jul 18, 2012 | 10:05 AM
Could still be the resistor pack, we had the same issue where it would work sometimes and not.
Old Jul 18, 2012 | 01:54 PM
I'm gonna take it to the dealer. Luckily, the do free diagnostics.
Old Jul 18, 2012 | 05:31 PM
It just quit again. Lolz. Story of my life.
04 Intimidator
Oct 19, 2011 10:42 PM
rj
Aug 11, 2010 10:50 AM
RocknSS04
34
Jul 16, 2010 11:38 PM
Gr4v3_7
Oct 7, 2007 04:18 PM
fever42
Nov 1, 2005 09:58 PM
