Wheel Corrosion
Old Sep 7, 2009 | 10:22 AM
labnjab's Avatar
Default Wheel Corrosion
Is there a way to stop corrosion on the outside of the wheel. Some one before me thought it was a good idea to use clip on wheel weights on the outside of the dale jr wheels, which is clear coated. When I got the car I saw this and switched to stick-on weights, but now the wheel is corroded where there clip on weights were because it rubbed through the clear coat.
Is there anything that I can put on the area to prevent further corrosion and to make it look halfway decent? I plan on eventually sending them in 1 at a time to a wheel place and getting them resurfaced but that won't be anytime soon because its not gonna be cheap
Old Sep 7, 2009 | 10:35 AM
are you talking about like salt damage? i have tons of that on my rims, in my case the only way to fix it is to sand down and repaint
Old Sep 7, 2009 | 01:14 PM
Check out the below link.
When the Bum's & I were clean'in detailing boats we would
use Flitz polish on all metal parts & it would remove the damage
from the salt air of the ocean. We would also use it on
car's we detailed that had corrosion on their wheels, and they cleaned up pretty good. Not for a show judge, but you would have to get
close to see the imperfections. Check the link
and see what you think. Hopefully one of our detail expect
tech member's will read your post & post their suggestions.
Good Luck
http://www.flitz-polish.com/
Old Sep 7, 2009 | 02:59 PM
I really don't know how to fix the corrosion except to get the wheels re-chromed. I have the chrome plated wheels on my DD and I am going to wax them really well before the winter and hopefully that will give them some protection.
Old Sep 7, 2009 | 04:49 PM
I had that exact problem on a previous car.
Since I was going to get the wheels re-done anyway, I cleaned off as much of the corrosion as I can. Then I carefully covered it with some clear nail polish. It wasn't pretty, but it was only gonna be temporary anyway. I'm sure there are better suggestions though.
I'm getting at least one of my Dale Jr wheels redone this winter when I take them off for the winter. Tire place used the grinder to clean the bead area when the original tires were replaced. This started the process of the aluminum corroding inside the rim. I already had one tire get a slow leak around the bead. Their fix? Grind my rim down some more UGGHHH!
I called a Chevy dealer and asked how much the factory original Dale Jr rims are. I got a price of $1300 EACH. Anyone coming near my rims with another grinder is getting an *** whipping!
Old Sep 7, 2009 | 08:38 PM
Enzo354's Avatar
STILL SLOW
U can get em off ebay for $100 a peice lol. But yea, just get some polish and polish it alot, mabye that will help.
Old Sep 9, 2009 | 06:21 AM
labnjab's Avatar
Thank you. I'll probably sand down the corroded area and put some kind of clear coat on it to stop any further corrosion and maybe put a coat of wax on it for the winter. I'm going to call up the wheel place and see how much they get to resurface and start doing them one by one, starting with the worst one. I'd love to get a set of winter wheels but none of the junk yards have gotten any in that will fit it
Old Sep 9, 2009 | 07:47 AM
MAMONTE's Avatar
I would either try some metal polish for light corrosion, and work at it till the corrosion is gone, or if its heavy corrosion, use some wet/ dry sand paper, and lightly sand away the corrosion. Then get some clear coat and toach up the section with some new clear to keep it from happening again.
Old Sep 19, 2009 | 04:54 PM
Marine57's Avatar
Taz, I just found the same problem with my right front rim. It wasn't holding pressure so I took it to the tire shop and they showed me the rim after they had the tire off. The problem was the corroded bead but worse is half the rim is corroded. I'm still in an extended warranty period so I'm going to see if it can be repaired or replaced. I'm also worried about my other rims.
Old Sep 19, 2009 | 07:34 PM
Marine57's Avatar
I found an eBay store selling rims. I'll put the link here, does anyone think this is or is not legit? It sure seems like the eay to go for me if warranty cannot replace or repair my rim(s).
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
