Air Ventilation
Old Sep 2, 2010 | 04:58 PM
rpd709's Avatar
Default Air Ventilation
Hello,
04 Monte SS Black w/ 172,500 miles.
Lately, when I hit a bump the air wants to cut out to low air even with the **** turned all the way over to the right, then at times I can hit another bump and it will go back to full speed like it should.
Is there something going on in the **** or is it the blower motor?
Old Sep 2, 2010 | 07:30 PM
nitehawkjcb's Avatar
Check for a vacuum leak in the engine bay. Do you have a supercharged 3800?
Old Sep 2, 2010 | 10:02 PM
rpd709's Avatar
Negative, Non supercharged 3800
I am missing a clip that secures the air filter assembly tight will that be the problem?
Old Sep 2, 2010 | 10:09 PM
It could be part of your issue. Check your brake booster hose, and every hose that attaches to it. On the S/C models, there are three vacuum lines on the top of the s/c (the upper intake in your case). Check around there.
Old Sep 2, 2010 | 10:26 PM
rpd709's Avatar
Any pic available to be able to see what I need to check
Also, where can I get those blasted little clips that clamps to the top of the air filter box.
shovelhead pete
Feb 10, 2011 12:17 PM
siouxcity04montess
Jun 5, 2010 05:49 PM
brpyne
Feb 19, 2010 04:25 PM
drewskie043
Dec 21, 2009 08:19 PM
White05LT
Nov 18, 2005 10:03 AM
