ABS Wires
Old Oct 30, 2010 | 10:04 PM
MRagland828's Avatar
Default ABS Wires
Where is the cheapest place to purchase the driver side abs wires? I have a 2006 Monte lt with the 3.5 flex engine
Old Nov 1, 2010 | 09:07 PM
Milhouse's Avatar
rockauto.com
Old Nov 1, 2010 | 09:20 PM
could you explain what problem you're having with your ABS? I am also having ABS and Trac Control issues, thanks
Old Nov 4, 2010 | 08:13 PM
Well I'll give you the story. Well I just replaced the wheel hub assembly because the wires coming from it were cut. Now the wires coming from the other end are cut. I am 100% sure that its the problem because I did a half *** job connecting the cut wires but both lights went off. I just want to eliminate the re-attached wires and get on solid wire from end to end.
Old Nov 4, 2010 | 08:19 PM
which hub did you replace? front or rear?
Old Nov 4, 2010 | 08:20 PM
Basically there are a pair of wires coming from the wheel hub and another pair coming from somewhere in the engine area. They meet together directly behind the brake discs of the front wheels. Check those to make sure they aren't cut. I have abs, tcs and service brake system lights until I connect those two clips together. I replaced just the front driver side because it was the only one that had cut wires.
THANKS DBS! You're the greatest! Saving me a ton of cash. Dealer was trying to get me for $100 not even including installation
michelob
Nov 10, 2013 06:55 PM
Cowboy6622
Feb 6, 2012 10:56 AM
buzdof
Dec 22, 2005 02:43 PM
blownss
Jul 25, 2005 07:41 PM
mickey
Jun 19, 2005 06:10 AM
