ABS Wires
Where is the cheapest place to purchase the driver side abs wires? I have a 2006 Monte lt with the 3.5 flex engine
rockauto.com
Originally Posted by MRagland828
(Post 272419)
Well I'll give you the story. Well I just replaced the wheel hub assembly because the wires coming from it were cut. Now the wires coming from the other end are cut. I am 100% sure that its the problem because I did a half ass job connecting the cut wires but both lights went off. I just want to eliminate the re-attached wires and get on solid wire from end to end.
which hub did you replace? front or rear?
Basically there are a pair of wires coming from the wheel hub and another pair coming from somewhere in the engine area. They meet together directly behind the brake discs of the front wheels. Check those to make sure they aren't cut. I have abs, tcs and service brake system lights until I connect those two clips together. I replaced just the front driver side because it was the only one that had cut wires.
THANKS DBS! You're the greatest! Saving me a ton of cash. Dealer was trying to get me for $100 not even including installation |
