6th gen. has 'water' in floor pas. side help!!
Old Jul 15, 2011 | 10:17 AM
thefuzz's Avatar
Angry 6th gen. has 'water' in floor pas. side help!!
OK nice sunny day 92* out a/c on high driving down highway for 30 miles stop at YMCA get out for 2hrs. come out an my wife opens the passenger door an yells what is in the floor?? I go over to find it SOAKED!!! i lift the floor mat out as CLAER WATER runs onto the ground the floorboard is soaked nothing else around is wet this is clear water? not anti freeze.. WATER... SO WHERE THE HE** DID IT COME FROM ?? soaked it up with some towels drove it home 30 miles with a/c on and you can hear the water splashing somthimes as the blower fan picks it up?? got home FLOOR IS SOAKED ???
Old Jul 15, 2011 | 10:31 AM
Sounds like a blocked AC drain??? Maybe some one with more mech. experiance will chime in here.
Old Jul 15, 2011 | 10:47 AM
Emnasty600's Avatar
That sound about right about the ac drain. remove the carpet from the passenger side and see if its coming from the firewall or from a hose, it may just be a loose clamp and an easy fix.
Old Jul 15, 2011 | 10:51 AM
Old Jul 15, 2011 | 11:01 AM
Mike 00LS's Avatar
Yep it's the drain. I had this same problem about 2 months ago. Here's a write up to fix it >> https://montecarloforum.com/forum/fi...equired-21645/
Old Jul 17, 2011 | 03:48 PM
05MonteLS's Avatar
While it looks similar, doesn't the 6th Gen have the A/C drain closer to the bottom of the car? Mine has a (roughly) 12" hose on the passenger side that goes from an area near one of the floor vents to the floor and coming out under the car near the cat. converter.. I think that's the A/C drain. The 5th Gen looks like it comes out of the firewall directly behind the engine.
If that's the case, I would think that the hose would come off easily so that it could be unplugged..
Old Jul 18, 2011 | 09:13 AM
thefuzz's Avatar
took the DRAIN HOSE OFF it was clear so I blew some compressed air in to the hole an apairently somewhere there was a clogg ALOT of the water started poring out so I put the hose back on an we'll give it a try ...
THANKS everyone !!!
MCSS06
May 29, 2015 08:04 AM
kat710
Jun 18, 2014 07:48 AM
77gp
30
Mar 22, 2012 05:34 AM
mikes03ss
Oct 23, 2009 11:34 PM
Brooke
Oct 17, 2007 04:35 PM
