2001 Monte SS Traction COntrol issue
Old Oct 5, 2011 | 06:47 PM
Shandley's Avatar
Default 2001 Monte SS Traction COntrol issue
Greetings,
Pretty much every time I pull away from a stoplight, my traction control steps in and slows me down. THe thing is, I am not spinning my tires at all so there would be no reason for this.
Any ideas why it might be doing this? I suspect the speed sensors are out of whack or busted up. If that's the case, where are these speed sensors located?
Thanks,
Shandley
Old Oct 6, 2011 | 12:46 AM
Sounds like a bad hub. It is a common problem with our cars.
Old Oct 6, 2011 | 08:20 AM
The speed sensors are in the hub assembly. Do you have the ABS light constantly lit as well after this happens?
That will give you the code to read, but a standard ODB2 code reader can't read those.
Old Oct 6, 2011 | 07:08 PM
j5atl's Avatar
I have the currently have the same issue with my 2001 ss.... sounds like these guys are dead on because I know my hub is bad (as I can hear the bearing starting to roar as i drive now) .... I picked up a new one today and plan on installing tomorrow... i'll post results tomorrow night when i'm done
Old Oct 7, 2011 | 11:43 PM
rj's Avatar
rj
Could this make the Traction light in the dash illuminate and another light that reads: Check Traction Control.
Old Oct 18, 2011 | 06:36 PM
Yeah I had the same issue when I had my 03 Monte. The sensors are in the wheel hub assembly. Mine went bad in the passenger rear hub assembly. The ABS light would randomly come on for a few minutes, then go off and disengage the traction control system altogether. Would usually do this every time I drove the car. Dealer replaced the wheel hub assembly.
chevygirl24
Jan 19, 2021 12:16 AM
Jul 8, 2012 08:27 AM
Chevy305
Mar 21, 2011 08:23 PM
ShadowCVL
Jan 5, 2011 07:21 PM
01montesf
Aug 11, 2009 12:40 PM
