2000 monte carlo
Old May 21, 2010 | 09:55 PM
stepheyhillhouse's Avatar
Default 2000 monte carlo
I have a 2000 monte carlo ss and had a bad problem with it not starting, and radio lights and blinkers work periodically, took it to the dealership and it said I had a bad BCM.. Replaced it and then they said the dimmer switch is bad but it starts everytime.. said I'd wait on switch and it started right up for about 3 days then went to crank it up and it didn't start.. waited a few mins and tried a few more times it started.. then read to try in neutral if doesn't start and it starts in neutral if it wont crank.. does anyone know why this is? and no I haven't fixed dimmer switch yet.
Old May 25, 2010 | 02:33 AM
seawolf18's Avatar
A defective neutral safety switch will allow you to start in neutral if it doesn't start in park. If you need a new dimmer switch, replace it yourself. It actually quite easy.
Old May 27, 2010 | 01:57 PM
Angry 2000 monte carlo
ok for the first couple times it didn't start I tried starting in neutral..and it started..yesterdY IT WOULDN'T START TRIED EVERYTHING AND NOTHING..i TRIED FOR A HALF HOUR TO START THIS CAR AND this morning it started right up..
Old May 28, 2010 | 11:53 AM
Dyonysis's Avatar
Common issue. See https://montecarloforum.com/forum/sh...418#post230418 or Search "Passlock" in the forums.
billyp35
Feb 1, 2007 08:00 PM
TGAbreu
Dec 9, 2006 10:31 PM
Mike
Aug 29, 2006 10:33 PM
00pacecar
Jul 6, 2006 02:18 AM
te100
Jan 29, 2006 05:31 PM
