06 MC needs help...
Old Dec 2, 2012 | 08:23 PM
Red Nightmare's Avatar
Originally Posted by StLBernMC
I have no idea what an air chisel is but im willing to learn lol. Glad there are forum members near me
Think of a jack-hammer just on a much smaller scale powered by a air compressor.
took a total of 4 combined hours(two seperate days) just wacking at the same spot over and over....
Make sure you have a full can of PB blaster, ft/lbs torque wrench, locktite & some white lithium grease or anti-seize.
Take a good look at this, it helped me out alot
https://montecarloforum.com/forum/si...ssembly-33657/
Old Dec 2, 2012 | 08:34 PM
StLBernMC's Avatar
That sounds like im gonna learn alot. Thanks for the heads up with all that
Old Dec 2, 2012 | 08:38 PM
Air chisel
Old Dec 3, 2012 | 01:24 PM
StLBernMC's Avatar
@zjerry. do you have one of those? Im pretty sure we have one in the auto/hobby shop on base tho. if you or mike could help we could rent out a spot in the hobby shop here
Old Dec 3, 2012 | 03:49 PM
I can help ya out either Friday or Saturday, & ill bring my Monte up this time lol
Old Dec 4, 2012 | 01:51 PM
StLBernMC's Avatar
Cool...just shot you a text
Old Dec 8, 2012 | 01:49 PM
Got the bearing changed in less than an hour
Old Dec 8, 2012 | 03:58 PM
StLBernMC's Avatar
Thanks again mike. That had to be record timing for a bearing change. If you really think about it...the actual change took less that 45 mins. Still had to lift the car and clean up the bay afterwards
Old Dec 9, 2012 | 07:47 AM
pilot2411's Avatar
if you suspect it is a bearing, you can drive at the speed the noise is happening, and swerve (carefully!) from right to left, and see if the noise stops, or changes in a particular direction. point to remember, if you are turning left and the noise is still happening, it is the right side bearing, this being from the weight transfer of the vehicle. also, if you have access to a jack or lift, you can raise the car and in some cases a slight shake on the tires may show some slack in the hub. a good hub assembly should not turn very freely. when you get it off the vehicle you also may be able to turn it and hear some noise in the assembly itself.
missgee
Aug 31, 2008 03:46 AM
brutemonte
Aug 29, 2008 08:06 AM
posthum_n
Jun 20, 2008 07:41 PM
paintballproam
Aug 7, 2007 03:28 PM
MING THE MERCILESS
May 31, 2007 08:31 PM
