06 MC needs help...
Old Dec 2, 2012 | 07:47 PM
Yup hub & bearing are all one unit
Old Dec 2, 2012 | 07:50 PM
I'm just a little curious to this, there are no codes showing up? When I had to replace a bearing I remember that either my ABS light was on and or service traction control message appeared?
Old Dec 2, 2012 | 07:51 PM
Mine never showed a code when mine went bad
Old Dec 2, 2012 | 07:54 PM
I know mine did, and Mike you have a 6th gen so there may be a difference between the 6th and 7th gens?
Old Dec 2, 2012 | 07:57 PM
I changed both in my wife's Impala SS no codes ..
Where are you in St.Louis ? Iam at 55/141 area
Old Dec 2, 2012 | 07:58 PM
Could be a slight difference, but codes could result in issues with the sensors over the actuall bearing
StLBernMC's Avatar
My service light JUST came on lol. So I haven't gotten it read yet.
Old Dec 2, 2012 | 07:59 PM
StLBernMC's Avatar
@zjerry.....i live over by Scott afb
Old Dec 2, 2012 | 08:08 PM
Red Nightmare's Avatar
I'm just a little curious to this, there are no codes showing up? When I had to replace a bearing I remember my that either my ABS light was on and or service traction control message appeared?
It all depends on what is going wrong with the hub really...
all the abs is just this ring that sits inside. If there is rust inside (its common for the inner bearing seal to leak water) the sensor won't detect it unless it shorts or begins to slip.
the abs ring:
http://img.photobucket.com/albums/v2..._MG_8850-1.jpg
All it was is the metal ring, plastic and the wire soldered to the plastic part.
If you are doing the hub, have fun. Have plenty of thin pointed flat-head screwdrivers. I went through about 4 & broke a hammer handle. Unless you got a air chisel...your life will be easier :P
Old Dec 2, 2012 | 08:17 PM
StLBernMC's Avatar
I have no idea what an air chisel is but im willing to learn lol. Glad there are forum members near me
