~ Brake Pads/Dust + More ~
Old Jul 13, 2007 | 11:54 AM
  #41
Default RE: ~ Brake Dust Monte Carlo's ~
[align=center]
ORIGINAL: cain45
Wow 10-12K miles! JEEZ what are they mario andretti? LOL....I was just curious did we confirm that the 06-07's have ceramic pads? I do know they have dual piston front calipers now and the older models didn't.
[/align][align=center][/align][align=center]`Hi James & Members,[/align][align=center][/align][align=center]Below is what I could find on OEM Replacement Pad's for 06/07 Monte Carlo[/align][align=center][/align]
ProducChevyBrake Pads - Akebono
Fits Years: 06
Fits Body: V6 3.9
Brake Pad Set Pro-ACT Ceramic w/Shims
N1010-235936
In Stock
Akebono (OEM)
$126.85
$84.95
[align=center][/align][align=center][/align]
When Are Squeals Signaling a Problem?
Sometimes, your GM vehicle's brakes will alert you when there's trouble. Brake squeals are an indication that maintenance is required. Here are some common causes of brake noise.
[*][align=center]Worn brake pads [/align][*][align=center]Heat cracked or worn "un-true" rotors [/align][*][align=center]Rough finish on resurfaced rotors [/align][*][align=center]Loose fitting brake pads in the caliper [/align][*][align=center]Lack of silicone compound on back of brake pad [/align][*][align=center]Missing springs or anti-rattle clips that should be on the caliper or pad [/align][*][align=center]Improper tightening sequence of lug nuts or caliper hardware [/align][ul][/ul][align=center]
Vehicles often come equipped with a small thin piece of metal attached to the brake pad to act as a warning indicator when the pad material is getting low and the brake pads should be replaced. This warning device can be deceiving though, because this warning noise is present when the brakes are not depressed. When the brakes are applied, the warning noise goes away because the indicator has now been forced against the brake rotor and is not able to vibrate which causes this whistling noise.
If one hears disc brake noises other than a squeal, it could mean the brake pads are worn out and need to be replaced. If your brake pedal feels different than normal or if you've noticed any change in the way your vehicle brakes (pulls to one side when braking or requires more pressure on the brake pedal), have the brake system inspected at your local GM dealer immediately.
Get more Goodwrench Tips about brakes
Genuine GM Parts[/align][align=center][/align][align=center][/align][align=center]When you head down the Goodwrench Service lane at your GM dealer you can be sure they are carrying a full line of Genuine GM Parts, each one designed and manufactured to exacting standards for your specific GM vehicle. So when you need your brakes replaced, the Goodwrench Brake Service is sure to give you Genuine GM Parts. [/align][/align][/align][/align]
Old Jul 13, 2007 | 12:28 PM
  #42
cain45's Avatar
So the new ones are ceramic? Wow I know the old ones weren't. Is this for front & back or just front? Do you know the GM part#?
Old Jul 13, 2007 | 12:33 PM
  #43
GrandPaDave's Avatar
ORIGINAL: cain45
Cain, I am guessing it is just the front. I wipe down my rims every day and the front rims are virtually immaculate while the rear rims have a black residue.
Old Jul 13, 2007 | 12:34 PM
  #44
Thanks Space for another great link that I have added to my favorites.
Old Jul 13, 2007 | 12:40 PM
  #45
cain45's Avatar
Nice anyone got a GM part #?
Old Jul 13, 2007 | 12:55 PM
  #46
ORIGINAL: cain45
[align=center]Hi James -Cain45-,[/align][align=center][/align][align=center]I searched for the parts number on the GM site, but could[/align][align=center]not find the parts #. Aren't you a good friend with your[/align][align=center]Parts Manager @ your Chevrolet Dealer.[/align][align=center]One phone call away.[/align][align=center]Oh, will yo do my homework for me : ) j/k[/align][align=center][/align][align=center]I did find this performance brake kit below.[/align][align=center]I will search again later, got to go to work : ([/align][align=center][/align][align=center]
Front Disc Brake Pad Kit | Part No.12498644[/align][/align]Front Disc Brake Pad Kit
Attain increased braking performance with 12" vented disc rotors and high-performance brake pads. The kit includes rotors, caliper mounting brackets, pads and bushings.
[/align]Click below link:[/align]http://www.gmperformanceparts.com/Pa...p;sku=12498644[/align][/align]
Old Jul 13, 2007 | 02:34 PM
  #47
cain45's Avatar
That link is for 12" upgrade for 00-05 Monte Carlos. 06 & 07s already have 12" rotors.
Old Jul 14, 2007 | 01:47 PM
  #48
Default RE: ~ Brake Pads/Dust + More ~
Buy Chevy Brakes and Chevy Brake Pads Here
Back to Power Slot Rotors
Chevy Brakes
. Upgrade to high performance Chevy brakes with us and you’ll feel the undeniable difference these spectacular Chevy brakes make. Get the longest life and outstanding durability only our Chevy brakes can offer.
No additional shipping charge on Chevy brakes orders over $50.00
Save as much as 70% on your next purchase of Chevy brakes when you shop with us
Chevy Brake Pads
Once your Chevy brake pads have worn down to about 1/8th of an inch thin, its time for a replacement. Why not upgrade to some high performance Chevy brake pads to optimize your stopping power and add longer life to your braking system. Our online catalog features Chevy brake pads at discount prices. Shop with us for your new Chevy brake pads 24 hours a day, 7 days a week.
The largest selection of Chevy brake pads on the web
Up to 60% off your Chevy brake pads from us
Daily Deal on Chevy Brake Pads
Part #: DP21142
Fits: "Front, Green Stuff Compound"
Notes: "Triple award winning EBC Greenstuff pads are now available in an upgraded AF44/78 formulation for most European cars. EBC Greenstuff is an excellent fast A road pad for all road legal cars, but is not for track day use."
Engine: 3.4L
Your Price: $95.81
Old Jul 14, 2007 | 04:46 PM
  #49
[align=center]Shop for Brembo Brakes, EBC Brakes,[/align][align=center]EBC Brake Pads, Hawk Brake Pads and Power Slot Rotors at savings off retail prices. [/align][align=center][/align][align=center][:-]Click below for Monte Carlo Brakes + more [:-][/align][align=center][/align][align=center]http://www.allperformancebrakes.com/brakes.html[/align][align=center][/align][ul][*][align=center]Largest Selection of Performance Brakes on the Web. [/align][*][align=center]Save money off Retail Price. [/align][*][align=center]Orders Made Before 3pm EST Usually Ship the Same Day. [/align][*][align=center]High Quality Brands Such As: EBC Brakes, Hawk, and Power. [/align][/ul]
[ul][*][align=center]Largest Selection of Replacement Brakes on the Web. [/align][*][align=center]Free Shipping on Any Purchase Over $50! [/align][*][align=center]Live Help Available 24 Hours a Day. [/align][*][align=center]Call Toll Free Any Time of the Day. [/align][*][align=center]All The Brembo Products You Want [/align][/ul]
Old Jul 18, 2007 | 08:41 AM
  #50
[align=center]
[/font]Kleen Wheels
Brake Dust Covers
[IMG]http://us.st11.yimg.com/us.st.yimg.com/I/rodi_1953_38311038" width=140 align=left border=0>
Your alloy wheels are like any other valuable investment. You need to protect your investment. Kleen Wheels are dust shields which protect your wheels from brake dust. Brake dust can ruin your wheels. It can cause the finish to corrode and deteriorate. Use caution when using cleaning agents containing harsh or abrasive chemicals which can strip away the wheel's protective coating, break up the paint or attack the aluminum alloy itself.
KLEEN WHEELS is the smart permanent alternative. Made of high strength aluminum alloy. This amazing product fits securely between the hub and wheel just like an inside hubcap. The patented turbo-venting design enhances brake cooling.
They are very easy to install, (Fits in the wheel just like an inside hubcap), turbo vented, and most of all, they keep your wheels shiny clean. Once you purchase Kleen Wheels Dust Shields for your vehicle you will never have to scrub your wheels again!
REG: $49.95 SALE: $37.95
Features:
[ul][*]Keeps wheels shiny like new, protects from damaging brake dust. [*]Easy to install - do it yourself (No special tools needed). [*]One piece no-maintenance aluminum alloy. [*][size=2 valign="top"]Sizes available to fit most cars, trucks, and suv's equipped with factory wheels.[/font][*]Will not affect new car warranty. [*]Includes (2) dust shields. [*]
Chevy Monte Carlo Brake Dust Shields - Top Sellers
Product Description
Price
1349 Kleen Wheels Brake Dust Shields
2000 - 2005 Chevy Monte Carlo
- (20 Slot Design), 16' Alloy
List Price: $46.19
Your Price: $36.95
2148 Kleen Wheels Brake Dust Shields
2004 - 2005 Chevy Monte Carlo
- (5 Spoke Diamond Cut), 17 Alloy
[IMG]http://www.car-stuff.com/images/html/small_truck.gif"> Usually ships within 1-2 business days.
List Price: $46.19
Your Price: $36.95
[/ul][/align]
[align=center][/align][align=center]Click below link[/align][align=center][size=2]http://www.car-stuff.com/mmparts/che...t_shields.html[/align]
