Info: ScanGaugeII - Additional xGauge Settings
This thread is intended to be growing/living collaborative effort to build a reference of additional settings MCF.com members obtained that can be programmed into the xGauge settings on the ScanGaugeII (and expand it's features).
If you have additional settings not documented already on the Linear Logic (manufacturer of the ScanGauge) web site, please share them in this thread.
Quickly, for those unfamiliar with the ScanGaugeII, it is a device that can offer up to four different read outs of data coming right off your PCM. Out of the box, it provides some great options, but to make the product more versatile, the manufacture has a section known as xGauge, which allows the end user to program additional gauges of data to monitor.
I contacted Linear Logic's Tech Support and got assistance making changes to fit my needs and that's what prompted me to start this thread (I'm sure some of the other ScanGauge owners shared my interests or had additional ones of their own).
Note: Sometimes the value 01 needs to be added to the end of a TXD to get the XGauge to work. This is why there is a (01) at the end of each of these XGauge’s TXD line.
NAME: FTC (Fuel Trim Cell or Engine Long Term Fuel Correction Index)
PID: 1190
TXD: 6C10F122119001
RXF: 046205110690
RXD: 3008
MTH: 000100010000
Fuel Trim - Tenth Decimal Position
PID: 7
TXD: 686AF10107
RXF: 044185070000
RXD: 2808
MTH: 07D00100FC18
PID: 6
TXD: 686AF10106
RXF: 044185060000
RXD: 2808
MTH: 07D00100FC18
NAM: GER (Current Gear)
PID: 199A
TXD: 6C10F122199A(01)
RXF: 04620519069A
RXD: 3008
MTH: 000100010000
The reported data will be as follows:
00=Neutral
01=First Gear
02=Second Gear
03=Third Gear
04=Fourth Gear
05=Fifth Gear
06=Sixth Gear
07=Reverse
08=Park
09=Low
PID: 1190
TXD: 6C10F122119001
RXF: 046205110690
RXD: 3008
MTH: 000100010000
PID: 7
TXD: 686AF10107
RXF: 044185070000
RXD: 2808
MTH: 07D00100FC18
PID: 6
TXD: 686AF10106
RXF: 044185060000
RXD: 2808
MTH: 07D00100FC18
PID: 199A
RXF: 04620519069A
RXD: 3008
MTH: 000100010000
00=Neutral
01=First Gear
02=Second Gear
03=Third Gear
04=Fourth Gear
05=Fifth Gear
06=Sixth Gear
07=Reverse
08=Park
09=Low
Only you Jason, a true blue MANIAC takes things to this next level. It's cool, hope the users on the forum can help put forth a few ideas. Take care bro...
06MC
Jan 6, 2008 05:15 PM
