Repair Guide: Rear Defroster Fix (Circuit Breaker)
Old Mar 24, 2014 | 09:16 AM
  #31
Lorraine Antonia Mereya Corso's Avatar
Ok it's not the circuit-it is the connection on the glass itself. We are going to try and solder it back, but if it doesn't work do I need a whole new rear window?
Old Mar 24, 2014 | 09:35 AM
  #32
There have been many different solutions regarding the glass issue. Make SURE the glass is not cold when someone goes to soldier the connector tab (risk of cracking/shattering the glass).
Some people have reported success with a product sold at the part store (for lack of better terms, it works like a glue, but is connective to allow the defroster to work again).
Old Mar 14, 2015 | 07:04 PM
  #33
child_of_fire's Avatar
which breaker is for the seat and which one is for the defogger? when i open the glove box i can see a 30 amp silver breaker to my right and i can grab it with needle nose. is this the correct one?
Old Mar 15, 2015 | 09:02 AM
  #34
I had to look at the pics I put in page one of this thread (as I honestly did not recall).
It looks like it's the bottom breaker.
I believe the circuit breaker in clear view on my pics when the fuse panel is still in the car is for the power seat controls. This is why I pulled the fuse block (it didn't take long to pull and I had unrestricted access to both breakers).
Old Mar 15, 2015 | 08:22 PM
  #35
ok thanks! i will have to wait for it to get warmer out...
if i pluck that breaker the power driver seat should cease to work correct? i guess thats one way of checking lol
Old Jul 17, 2017 | 12:14 PM
  #36
tucker's Avatar
FYI I just performed this yesterday. It took 8 minutes. No need to unbolt wiring harnesses ect. I folded the glove box open, removed the 10mm bolt from the back, removed the fuse panel access door . I was able to flip the panel over and replace the cuircut breaker. And YES my old breaker rattled when shaken also.
Old Jul 17, 2017 | 10:17 PM
  #37
Awesome tip.
Sad how common an issue this is and where the circuit breaker is hidden.
Old Jan 5, 2019 | 04:04 PM
  #38
Old Crow's Avatar
I know this is an old thread but I just did this today on a 2004 Impala. I didn't unplug any harnesses. I disconnected the battery, removed the fuse cover, removed the glove box and the 10mm bolt next to the power seat breaker. This allowed the fuse block to be pulled out far enough to remove and replace the defroster breaker. I did unseat one relay in the process but that was it.
Old Feb 8, 2024 | 12:17 PM
  #39
sparkyallen1's Avatar
Were you ever able to find the kit or repair the connection?
Old Feb 8, 2024 | 12:23 PM
  #40
SSmokybear's Avatar
I did!
https://frostfighter.com/defroster-r...g-kit-2000.htm
benhillzone3
Oct 29, 2013 10:59 PM
weizie
Oct 14, 2009 12:21 AM
5207234w
Feb 23, 2009 11:07 PM
metalhead
Sep 30, 2008 03:22 PM
white_angel123
Feb 29, 2008 02:41 AM
