Mod Guide: 2000 Monte Carlo Amp Bypass
i posted the oem wire harness schematics - HERE. In case anyone wants to do this.
Just use a 9-volt battery to check for a speaker's polarity. When the cone of the speaker is extended "out", you have correct polarity - just mark which one you have + & - on, & you are all set ... make sure all are done this way or you will have some in phase, & some out of phase, & everything will sound muddled.
I followed the bypas imstructions and got 2 out of 4 speakers working then adjusted the balance to properly check the others and I hurd a very slight crackle coming from the speakers I had hooked up and now I have no sound again. Stereo plays CDs but no sound or chime again. Any tips? Could I have blown something up? Is there a fuse I can check?
I work at a stereo shop and I took some leftover wiring harness kits and made an amp bypass plug.
Also, as you can see, I'm apparently OCD about wires...
rmase182ls
41
Jan 18, 2026 12:32 PM
Silver SLP
Mar 29, 2015 06:20 PM
NovaSS369
Dec 25, 2011 09:44 PM
