2000 Monte Carlo Amp Bypass
If your amp is going bad in your car, take both clips on the am, and cut all the wires. Leave some left if you ever feel like going back to a stock amped system.
These will be hanging and free, tape them so nothing touches Black Purple Thin white Orange Here are the connections you need to make *note this is a 2000, I have no idea on 2001 and up* Also there are 3 tan ones, so take your time and test each one out to make sure its the right one, dont go clamping right away. http://i130.photobucket.com/albums/p...354/bypass.jpg I think my stock system sounds louder without the amp and works great. I have no idea on long term effects but for now I love it. |
wow, I thought you were celebrating something, I guess you discovered a good thing with your non-amp now monte carlo?? like you said, what are the long term effects? I guess you will let us know!
Anyone know if this will work on an 01'? Buddy of mine crossed a couple of wires when hooking up my subs to the stock radio and fried the stock amp. Let me know please?
What the... Well, I've done worse. Glad it worked out for you though.
Should work on a 01. I sat in the trunk and messed with them for about an hour and kept chaging the fade an balance to get the right ones.
Originally Posted by Enzo354
(Post 258413)
Edit: It worked! Thank you very much. Months of riding around with no music was horrifying!! |
Originally Posted by JD_01_SS
(Post 258586)
Thanks. I do believe I'm going to try it today. Wired up some neon's yesterday so that's on the agenda for today.
works great
thanks enzo for the wire pic , works great
can i use this to tap into an aftermarket amp?
Maybe, I'm not very familiar with them.
