Will 3.4 radiator work in 3.8 SS?
Old Feb 28, 2013 | 08:27 PM
LilSeanCB's Avatar
Default Will 3.4 radiator work in 3.8 SS?
Sorry if this is in the wrong section. I just want to know if I can put a used radiator from a 3.4L Impala into my 3.8L Monte. The radiator is used but tested and comes with warranty. I do not have $300 for a New AC Delco and refuse to get a new generic one off eBay thats $60 and will probably need replaced after a month, Junkyard has the radiator btw for $50.
Old Feb 28, 2013 | 08:50 PM
rockauto.com $195.79, AC Delo part # 21560 is for a 3.4 and a 3.8 Monte. They are the same part for both models......
Check it out for yourself and you can use that site for other compatible parts in the future.....
edit: I thought you were looking for 3.4 and 3.8 Monte, not an Impala...They are not compatible......
Old Feb 28, 2013 | 09:23 PM
Napa web site Lists them as the same..3.4 or 3.8 Impala or Monte ..
Old Feb 28, 2013 | 09:26 PM
LilSeanCB's Avatar
Ok thanks! I'm going to go ahead and get it then.
Old Feb 28, 2013 | 09:31 PM
There are 2 types for the Impala though.....
Old Feb 28, 2013 | 09:46 PM
Yeah one is 5/8" core the other is 1" core..
Part Number: NR 2689
Product Line: NAPA Radiators
IMPORTANT INFO: 5/8" Thick Core
Part Number: NR 2890
IMPORTANT INFO: 1" Thick Core
Old Feb 28, 2013 | 09:48 PM
I had to double check atleast 5 times for each.........
You never know and if you do buy from a junkyard there could be a "no returns" policy!
killerBee
Jul 1, 2018 02:14 PM
turner_dtp
Mar 30, 2007 04:01 AM
zipsayain
Feb 25, 2007 02:23 AM
wildchild00
Jan 22, 2007 05:37 PM
USELESS
May 11, 2006 11:32 PM
