Will 3.4 radiator work in 3.8 SS?
Sorry if this is in the wrong section. I just want to know if I can put a used radiator from a 3.4L Impala into my 3.8L Monte. The radiator is used but tested and comes with warranty. I do not have $300 for a New AC Delco and refuse to get a new generic one off eBay thats $60 and will probably need replaced after a month, Junkyard has the radiator btw for $50.
rockauto.com $195.79, AC Delo part # 21560 is for a 3.4 and a 3.8 Monte. They are the same part for both models......:thumbsup:
Check it out for yourself and you can use that site for other compatible parts in the future..... edit: I thought you were looking for 3.4 and 3.8 Monte, not an Impala...They are not compatible...... |
Napa web site Lists them as the same..3.4 or 3.8 Impala or Monte ..
Ok thanks! I'm going to go ahead and get it then.
Originally Posted by zjerry
(Post 531430)
(Post 531432)
There are 2 types for the Impala though.....
Part Number: NR 2689 Product Line: NAPA Radiators IMPORTANT INFO: 5/8" Thick Core Part Number: NR 2890 Product Line: NAPA Radiators IMPORTANT INFO: 1" Thick Core |
I had to double check atleast 5 times for each.........:confused:
You never know and if you do buy from a junkyard there could be a "no returns" policy! |
