white engine smoke?
Old Jul 24, 2013 | 03:44 PM
blackmonte02's Avatar
Default white engine smoke?
I bought a 2001 Bonneville SLE with the non-supercharged 3.8 L and this afternoon it had trouble turning over when you turned the key and there was white smoke coming from the engine bay. There weren't any lights that came on the dash either. Anyone know what the most likely problem is?
Thanks
Old Jul 24, 2013 | 04:09 PM
nitehawkjcb's Avatar
Coolant leaking on exhaust probably
Old Jul 24, 2013 | 05:02 PM
Thanks
Possibly a blown head gasket...Broken Coolant Elbow..????
Radiator leak.... worn out/cracked radiator hose...possible oil leak, vacuum line leak ...
Old Jul 24, 2013 | 09:27 PM
Does the car start? Maybe it something electrical like the starter. Maybe you could give us some more info or possibly post a video.
Old Jul 24, 2013 | 11:20 PM
I came back 4 hours later after work and it started up just fine. I am not sure why. I did not see anything leaking on the ground or on any of the components of the engine bay.
The car does start but sometimes it doesnt wanna turn over very well. This happened a couple times were it would start but it wouldnt be at a high RPM and than it would idle at a higher RPM
Thanks for the info...i scheduled am appointment for it tomorrow morning sp hopefully it works than or find the problem!
SoCal01Monte
Jun 25, 2012 10:30 AM
tdunbar5
May 16, 2010 12:46 AM
ltrain925
Dec 22, 2009 11:39 AM
85MonteSSwhite
Apr 5, 2005 09:18 PM
