What is going on with my car?
Old Feb 19, 2013 | 08:07 PM
mokepete's Avatar
Default What is going on with my car?
I have a 2000 Chevy Monte Carlo and as I was driving the check engine light came on, the car stopped accelerating, but the RPM's continued to go up. I switched to every gear and nothing worked. I turned the car off and back on and it goes for about a mile and does the same thing again. HELP!!!!
Old Feb 19, 2013 | 09:12 PM
Check and clean the MAF sensor, TPS throttle position sensor, IAC idle air control.. and see if that doesnt resolve your issue....
If not then quite possibly...Your transmission is failing... I would also consider a fluid and filter change if checking and cleaning those sensors dont help....
How many miles on it? That also makes a diference...
Old Feb 19, 2013 | 09:15 PM
Could also be a bad catalytic converter?
X2
Old Feb 20, 2013 | 07:34 AM
Definitely sounds like a transmission issue to me.
KINGBASS
Aug 2, 2015 09:19 AM
Sadmonteowner
Jul 30, 2015 01:30 PM
CB_MOTORSPORTS
Jul 16, 2011 02:05 PM
Ds 01 MC
Jun 23, 2007 09:55 PM
Dialuas
Apr 30, 2007 03:05 PM
