Water/Meth kit here!!
Yeah I heard better suited for turbo set up but i dont think it would really make a differance as long as you have some kind of power adder on the engine. I know a guy who has it hooked up on his Grand National and when he presses his wind shield cleaner it sprays the mis into his engine.
It's actually better suited for supercharging than turbos
i don't know much on the meth injection, but from little i read on other forums they use tb spacer and tap in the nozzle spray there. also heard there's a lot of good tunning involve for HP gain.
You dont need any tuning if you dont want to. One key feature with water/meth kit is the ability to run more boost because of the temp drop when entering the engine. The motor might not take the extra boost mechanically but the mixture keeps the temps down. So the temp with the water/meth kit at 10 or 11 psi has a temp equivalancy of 5 or 6 psi.
yup never heard of it but i also havn't been in the market for a turbo and or related items to go with it, and thanks for the clarification
