Water/Meth kit here!!
Ordered an AEM universal water/meth kit for for my turbo/intercooled 03 ss and cant wait to get it hooked up. I'm gonna get a mount fab'd up to mount it in the trunk as it's the only place it will fit. Attached a pic I'll put more up when i get it installed.
water into your throttlebody? so you'll be introducing water into your motor? that just sounds like a good way to destroy a perfectly good motor...
The water is shot while mixed with Methanol in a very very fine spray. The water isn't actually going into the engine, the second the water hits the high heat of the combustion chamber it evaporates and brings the heat out with it.
Then the Methanol acts as an octane booster and allows the car to be tuned more aggressively.
It is basically just a chemical intercooler.
edit- beat me to it, thats what I get for opening multiple windows at once.
It's actually better suited for supercharging than turbos, according to my tuner in Canada. It makes your 91 octane into about 112 octane. People typically use the -35 deg windshield washer fluid as the mix, and some use the washer fluid bottle as their tank.
