vapor lock
Old Aug 15, 2010 | 12:49 PM
1970monte454's Avatar
Default vapor lock
ok well i think ive figured out why the monte runs so bad when it gets warm.i think it is vapor lock.what exactly is this?where does it occur?(ie.between pump/carb,tank/pump)how can i get rid of it?and the cheapest way i can.thanks for any input.
the car is a 350,mechanical fuel pump.inline fuel filter about 6in away from carb.had the tank out to clean check fuel lines goin into tank all looked good
Old Aug 15, 2010 | 12:57 PM
Hope the below link helps...Check back on you thread to see what our expert tech member's post....Good Luck 4-Sure
http://www.wisegeek.com/what-is-vapor-lock.htm
Click above link,
it has some good infor on vapor lock...
Wrap your fuel lines or a shield from the `heat
Old Aug 15, 2010 | 01:08 PM
thanks kid.ill get right on reading that
Baby Jesus Swag
Apr 13, 2015 08:58 PM
DerrtyD
Apr 26, 2013 11:49 AM
sixscarlo
Jun 17, 2012 07:31 PM
prometheus
Jun 3, 2006 04:35 AM
buddney
Jul 6, 2005 11:38 PM
