Type of transmission Fluid??
#32
What about Valvoline Maxlife Dex/Merc transmission fluid?
That's what I've used in my older GM vehicles. It says it can get used where Dex VI is called for, so I assume it is a Dex VI fluid.
Is it bad to mix Dex VI with Dex III? As I guess Dex III is in my 02 Monte.
Though, I had read some recommend sticking with Dex III if that is what came with it as the tranmission was designed for Dex III.
#34
Can the filter be driven in too far? That new filter didn't want to go in by hand. So, I had to tap it in, but wasn't sure if it could be tapped in too far?
I'm used to the older GM transmissions that just have a rubber seal that can easily be replaced by hand, and the filter gets removed/installed by hand.
#35
ithe only thing i did to help the life of my trans besides the intervals were adding a trans cooler to it to help it. i know i live in fl but when i was in va i put it on because all of the hills and evey thing. also i was told by a g, tech at the dealer to put it on to help it out for the long gevity of it. i didnt really notice the diference till i seen it took a little longer to warm up to operating temps. it is not a biggy as long as it stays cool
#36
I replaced that seal, but should have left it alone. As I used a seal puller and gouged the aluminum shaft. But I got the new seal pressed in and the filter installed. Though, I had to tap the filter to get it to seat. But I hope you can't press the filter in too far.
I've since read of people saying to avoid replacing that seal as you could gouge the shaft as I did. But didn't really read any comments on what could happen with a gouged shaft if the new seal was pressed in and the filter was able to be pressed in.
Visceron
10-25-2010 08:31 PM
Frosty LS1
08-15-2009 06:43 PM
