Opinion Needed: Turbo 3800
Old Jun 12, 2018 | 06:30 PM
hunterh047's Avatar
Default Turbo 3800
Sooo, I'm building a 3.8 bottom end for my new turbo build and I obviously don't need the dual ribbed balancer, so my question, is there a performance balancer anyone would recommend with just the single ribs. Also should I go with an overdrive or an undedrive pulley?
Old Jun 12, 2018 | 09:05 PM
First off, this would get more hits / replies in the engine section rather than the detailing section. Perhaps a mod can move it?
I wouldn't 'build' a bottom end. A junkyard engine is fine. If you're going to run big boost, get an L67 bottom, if moderate, then an L36 would be fine.
IMO it's a waste of money, especially for a turbo car. I've got an ATI and it's a very nice piece, but a new one is a lot of money for zero performance gain. It's not like you're going to be spinning crazy high RPM or anything on a 3800 anyways, and you don't need the extra ribs like a superchaged car would want.
If you had to get one - under drive would give a tiny bit more power. I'm personally not a fan though as it slows down all of your accessories too. That can be problematic, especially for greater under drives at idle.
Old Jun 12, 2018 | 10:27 PM
hunterh047's Avatar
Great answers, thanks for the quick response. I'm going to "build" the bottom end because I got the whole setup (60,000 mile l32 block and rods, new eagle crank, new aluminum pistons, and all that good stuff) from a guy nearby for pretty cheap so I might as well. So for my balancer I'll just run a better one for a N/A 3800. Otherwise thanks again for the help man.
Old Jun 13, 2018 | 09:51 PM
If that 60k mile L32 is still all together, I'd just leave it. No reason to tear apart a good engine.
One downside to building an engine is that even the machine shop work alone will cost as much as a junkyard engine.
I'm not really sure there are any 'better' ones for an NA engine than stock. I just took a look at the ATI site and it looks like their only option for a complete set is for a supercharged engine. You could always buy just the hub and have them custom make a shell without the outer ribs, but they're already awfully expensive to start with for an off the shelf model.
There are definitely a lot of replacement ones (Dayco, Dorman, Powerbond, etc) but I wouldn't say they're better than OEM.
SSBlue
May 17, 2016 07:00 PM
GTHSS
29
Jul 23, 2014 10:27 AM
monte07
May 21, 2012 10:34 AM
01devilss
Sep 10, 2011 08:18 PM
Jordanshedd5
20
Jul 27, 2010 07:59 PM
