troubleshooting a noise
Old Mar 20, 2012 | 09:40 PM
Gib's Avatar
Gib
Default troubleshooting a noise
2002 3.8L MC SS with 220,000 miles
It is a snapping sound louder than a spark jumping and throttle related. I am thinking it is an injector(s). It goes away if I rev the throttle a few times. I never had an injector go bad. Is there something else that goes bad this way?
Thanks in advance.
Old Mar 20, 2012 | 10:56 PM
You sure it's not a tapping sound? Could be a bad lifter or low on oil....
Old Mar 20, 2012 | 11:11 PM
A loud snapping and a spark??? Sounds like arcing to me. When arcing occurs, it causing mis-firing and RPMs to look goofy.
At night, sometimes if you mist water from a spray bottle, you can see where it's arcing. Usually it's a wire, so the other thing you can do it inspect each plug wire one at a time. You will probably find a a dark spot (and it may also feel "hard" compared to the rest of the wire).
Old Mar 21, 2012 | 09:57 PM
Gib's Avatar
Gib
It doesn't sound like a lifter or rocker. I did look under the hood in the dark and didn't see any arcing from the wires.
The wierd thing about it is that it goes away after a short ammount of time almost like a dry lifter. Are these rollers or hydraulic tappets?
It is due for plugs and wires so I'll dig into it soon. I really wonder if fuel injectors make noise sometimes?
84MC
May 16, 2011 04:49 AM
relaxo
Jan 1, 2011 02:45 AM
Gib
Dec 20, 2010 05:25 AM
DeanMachine
Sep 10, 2010 04:56 AM
Fort Lawrence
Oct 4, 2009 07:43 AM
