Amp/Radio Troubleshooting
Old Aug 30, 2010 | 12:24 AM
DeanMachine's Avatar
Default Amp/Radio Troubleshooting
A few months ago, my speakers started fading in and out. After that, they were cut off completely. I took it to a dealership recently to get something else check out, and I asked about the audio problem as well. Chevy said I needed a new amplifier, so I figured they knew what they were talking about and went out to get a new one. I just mounted my new Dual Audio XPA Series 4100 today, and went to work on the wiring. I got it so that there was power received by the amp and the REM connection was working fine (it was grounded too). My dad and I mapped out the speakers by plugging them directly into the radio (no amp), and then started working on putting the wires into the four channels. Now, I can get power to the amp, the radio turns on lights and such just fine, but no sound comes out of the speakers! We're almost positive that all of the speaker connections that we made are right. But just to be sure, we undid everything and tried to get the radio to play by itself without an amp again. This time, nothing came out of the speakers still...so here I am with a brand new $100 amp, wires down in my trunk, and a radio that won't play through the speakers!
Comments/Suggestions?
Old Aug 30, 2010 | 08:17 AM
is it the stock deck? howd you get the wires down to the rcas and into the amp?
Old Aug 30, 2010 | 09:49 AM
Just took them out of those plug n' play things. It wasn't that difficult to do so.
Old Sep 8, 2010 | 09:54 PM
bblackstone's Avatar
My speakers have done the same. I too can not figure it out. I will try a new amp, but I'm also getting power to it. Any answers would be great.
Old Sep 9, 2010 | 04:12 AM
NYGiantsfan's Avatar
if its a stock radio you need a hi/low converter with that aftermarket amp...if not plug the rca from the radio to the amp and wire it up make sure the amp is on then test it by running the speaker wires directly from the speaker to the amp channel if it works you best bet is to run separate wires from the speakers to the amp...i did it in my car like that but i ddnt have your issue the hardest ones are the front speakers as far as runnin the wires through but it shudnt take more than 45 min total good luck
Old Sep 10, 2010 | 04:56 AM
Will give that a shot. Thanks!
saigashooter
Feb 13, 2012 05:09 PM
84MC
May 16, 2011 04:49 AM
relaxo
Jan 1, 2011 02:45 AM
Gib
Dec 20, 2010 05:25 AM
Fort Lawrence
Oct 4, 2009 07:43 AM
