6th Gen ('00-'05): TROUBLE CODE p0410 Help!
Old Aug 11, 2015 | 05:59 PM
A block off plate is literally a piece of metal that will bolt in place on the flange to block off the connection and prevent exhaust gas from escaping.
I contacted ZZP and Milzy to see if either had one or knew of a pre-fab plate (like the EGR block off) that might work and neither knew.
I think a plate seen on the top of the L67 might fit that flange, but, I honestly don't know anyone who tried it.
As I said, my research to remove that Cali emission system came to a stop. Not sure my next stop to the junk yard, but if I can find the plate I think might fit, I can grab it and see if the local guy wants to give it a try.
Old Aug 16, 2015 | 05:30 PM
owens91's Avatar
would one be able to simply delete the code or might that effect the car?
Old Aug 16, 2015 | 08:24 PM
farmerjg's Avatar
Thread jack....do you really only get 16.8 MPG?!?! What are you doing when you drive? That's atrocious.
Old Aug 17, 2015 | 05:11 AM
owens91's Avatar
Well every since I got my TEP trans I've been getting 20 mpg atleast
Mike 00LS
Jul 24, 2011 10:52 PM
BIGAL131
Dec 5, 2010 10:55 AM
turner_dtp
Sep 5, 2008 04:32 AM
jeffsmonte
Aug 3, 2008 07:24 PM
chorales
Jul 24, 2005 05:33 PM
