Transmission Shift Linkage Problem?
Old Sep 10, 2006 | 08:18 PM
201fireman's Avatar
Default Transmission Shift Linkage Problem?
I have a 1972 Monte and I am having some shifter problems. The key will not return all the way back so I cannot get it out of the ignition. Also I have to start it in neutral because it will not start in park (however once running it does go into park nicely and lock in). The reverse lights on the rear bumper are also on when it is running and in park. I tried adjusting the linkage (ladder shifter on the floor) but it seems to be in the right spot. Does anyone know where I could go next?
ahjordan
Dec 30, 2011 02:40 PM
94wrangler4.0
Aug 14, 2011 08:09 AM
emacmonte
Jun 23, 2010 02:58 PM
powerguy5051
Nov 30, 2007 01:41 PM
fastback4
May 3, 2007 03:31 AM
