transmission flush
Old Nov 8, 2006 | 12:01 AM
2000_BLACK_SS's Avatar
Default transmission flush
how hard is it to do a transmissioon flush? is it worth doing it yourself or should i take it to local shop? also if i go to a shop what would a good price be.
Old Nov 15, 2006 | 07:50 PM
04MonteLS's Avatar
Default RE: transmission flush
the reason for a tranny flush is to get the contaminated, broken down fluid out and replace it with fresh fluid. Doing this at home you'd only be able to replace about 30% of the fluid by dropping the pan so I'd suggest you have a shop do the flush. Just make sure they do a pump inlet flush, not a cooler line flush.
Old Nov 16, 2006 | 12:46 PM
rchurch's Avatar
I've seen them for around $100. $95 low end, $115 high end price range. There was a thread on here a while back with some dicussion about type/brand of fluid to use. Anyone have any suggestions?
Old Nov 16, 2006 | 01:27 PM
04 Intimidator's Avatar
Cost is going to be determined by area. A normal transmission flush in my area is about $70. Also make sure the shop has the tools. We have a large dealership in the area, and by large I mean over 20 lots and probably in excess of 10,000 vehicles in a 30 mile radius, and they did not have a special tool that is needed for the Monte Carlo 2004. I don't know if this is needed for other 6th gen but it confused the heck out of me. This also came from their lead mechanic for about 15 years at the dealership. I checked the Saturn garage as well and they didn't have it either.
ashleymc34
30
Nov 1, 2009 10:03 PM
MAMONTE
Sep 25, 2009 09:34 AM
jaws2008
Feb 12, 2009 11:21 AM
ExplosiveSoundz
13
Feb 2, 2008 04:53 PM
RickCoMatic
Jan 9, 2008 03:09 PM
