Transmission cooler install question
If your engine temperature is good and you're not having problems overheating there- then you could mount it in front of the radiator. If you prefer to mount it somewhere else- you could mount it off to a side and duct air to it.
there is my Trans cooler thread for anyone looking for ideas>>>> https://montecarloforum.com/forum/ge...working-49146/
where is a great place to get cool air flow for an after market cooler? i plan on running it thru the rad cooler then aftermarket cooler. to take advantage of the rad heating in the cool but benefit from cooling during driving. i often have to drive in - 10 degree weather then 90+ weather so i need something capable of handling temp change
My altitude here in Utah has caused me cooling issues. Went with the larger radiator from the police Impala and the very high velocity fans from the same police package.
Have you checked to see how clogged your radiator fins are, run some water through them, they might be adequate for normal slow driving, but when the demand is there they cant cool the fluid adequately if the fins are restricted.
Also did you check to see if your Monte's front "Air dam" is still in place. Some people break theirs off pulls into parking spots and running over the stopper barrier. There has been more than one case on here of the dam being missing and when replaced the cooling issue was resolved.
cxt35
Jan 6, 2013 10:14 PM
Joe Thomas
Jun 8, 2009 09:23 PM
