Transmission clunk?
Transmission clunk?
Well I am kinda sad and kinda mad. I just about have all my suspension stuff and now I have a problem. When I shift into reverse I hear the shift but then two quick clunks. Sometimes it doesn't happen sometimes it does. It sounds like its coming from right under where the shifter is. Only happens when shifting into reverse. I was thinking transmission mount? Any ideas?
IDK, if you are hearing the two clunks after it shifts, I would say its internal. I think that if you had a bad tranny mount, you would be hearing clunking/ noise all the time, in any gear, forward or reverse.
