Transmission clunk?
Old May 15, 2010 | 11:18 PM
Pure2sin's Avatar
Default Transmission clunk?
Well I am kinda sad and kinda mad. I just about have all my suspension stuff and now I have a problem. When I shift into reverse I hear the shift but then two quick clunks. Sometimes it doesn't happen sometimes it does. It sounds like its coming from right under where the shifter is. Only happens when shifting into reverse. I was thinking transmission mount? Any ideas?
Old May 15, 2010 | 11:51 PM
MAMONTE's Avatar
First thing I would try is change your transmission fluid and filter. It can't hurt, and could help the problem.
Old May 16, 2010 | 02:21 AM
Pure2sin's Avatar
That was the next thing I was about to do. Could the filter or fluid cause a clunk under the shifter though? I thought mount because of it only doing it in reverse.
Old May 16, 2010 | 05:03 AM
iMSeRiOuS's Avatar
motor mounts?
Old May 16, 2010 | 08:59 PM
Pure2sin's Avatar
I could do the Motor and Transmission mounts without a cherry picker right?
Old May 16, 2010 | 09:30 PM
iMSeRiOuS's Avatar
you could use a jack to support the engine from underneath
Old May 17, 2010 | 08:28 AM
MAMONTE's Avatar
Its hard to say honestly. Is it clunking when you go into reverse, or does it clunk while you are backing up?
Old May 17, 2010 | 07:32 PM
Pure2sin's Avatar
No clunking when backing up. Just when I shift from park to reverse. Not into drive or anything just reverse. It shifts then I hear two quick clunks.
Old May 18, 2010 | 07:37 AM
MAMONTE's Avatar
IDK, if you are hearing the two clunks after it shifts, I would say its internal. I think that if you had a bad tranny mount, you would be hearing clunking/ noise all the time, in any gear, forward or reverse.
labnjab
Jul 1, 2009 08:51 PM
Endo
May 4, 2009 02:35 PM
White05LT
Feb 14, 2009 02:28 PM
Sciggy
Mar 5, 2008 08:08 AM
yzf125
Apr 30, 2006 11:21 AM
