Transhift Cable
Old Oct 15, 2018 | 06:06 PM
Leland Finney's Avatar
Default Transhift Cable
I have a 1985 Monte Carlo SS that is stuck in park and reverse. I replaced the transhift cable but cant get the floor shifter past park and reverse. I have a 200r4 automatic transmission. I replaced cable after the silver threaded cable snapped and I could move the shifter through the gears freely without hitting the brake and getting any resistance or catching any gears. Any help or tips would be greatly appreciated.
Old Oct 17, 2018 | 08:28 AM
Jeffs02rwdSS's Avatar
This is a little confusing so maybe you can re-word it differently . Being a 1985 I don't believe it has a shift lock on the brake. With the cable disconnected from the shifter does the shifter move freely thru the gears ? With the cable connected to the shifter and disconnected at the trans does it work properly ? I also remember that the steering collum would also rotate where the collum shifter would be when you went thru the gears on a 87 Cutlass we use to have is your the same ?
TSauer09
Jul 13, 2022 02:46 PM
TSauer09
Jul 22, 2013 07:40 PM
PhotoKIrk
Oct 16, 2012 10:05 PM
matrx10503
Dec 13, 2011 11:43 AM
Black Beauty '95
15
Dec 3, 2011 05:55 AM
