trans has no reverse
Old Sep 8, 2010 | 07:12 PM
meanmonte's Avatar
Default trans has no reverse
hi i'm new to the site and i just bought a 86 monte carlo not ss, it has a 400 sbc in it with a 700r4 transmission. i was told it has no reverse but all foward gears work just fine. i have been reading up on here and someone said that the column shift monte carlo's had 3 speeds in them... and that the 700r4 trans is a 4 speed. could this possibly mean that the stock 3 spd column shift just passes up the reverse gear on the 700r and it might actually be ok? thanks for readin and any help would be great.
Old Sep 8, 2010 | 10:41 PM
Budsjlm's Avatar
beign your car is a sc it originally had a th200 3 Speed, so you may be correct, one way you could check is put the rear end up on jack stands get some beer to bribe a friend or tell the g/f or wife u'll buy her somthing nice if she helps you disconect the linkage from the trans and have friend/girl start the car and then take a wrench small enought to fit where the tinkage bolts up, and run it trought the gears and see if it goes into revers if it does get yourself a floor shifter and then your golden!
Old Sep 9, 2010 | 05:51 AM
TheMonteMan's Avatar
agreed^^^
Old Sep 9, 2010 | 08:34 AM
The Popcorn King's Avatar
Thats exactly what i would do to check it. ALSO, make sure that who ever is working the pedals to make sure they put step on the brakes before you change gears from PARK-REVERSE and REVERSE-DRIVE and back again. Dont want to damage the trans if its just a linkage problem.
Old Sep 9, 2010 | 12:51 PM
meanmonte's Avatar
alright thanks alot fellas i'll give that a shot either tonight or tomorrow and if thats the problem..hurst quarter stick it is haha
PsuBrock
Feb 9, 2008 11:05 AM
KrackerJ
Jan 16, 2008 02:37 PM
DeboDaddy
Dec 20, 2007 07:15 PM
verdi219
Sep 4, 2007 07:40 PM
96monty
Dec 3, 2006 12:58 AM
