tranny problem
Old Mar 28, 2009 | 08:56 PM
joshtazz's Avatar
Exclamation tranny problem
when i first start my car and put it into overdrive or anythingit will not go anywhere but if i rev it real high it kicks real hard into gear fluid level is fine. and trany shifts very smoothly after that. i have a 3.1 liter monte v6
Old Mar 28, 2009 | 11:52 PM
jdizz's Avatar
could be a few things but i would have the valve body checked for stuck valves, or even the shift cable for stretching.??? maybe?
Old Mar 29, 2009 | 04:15 AM
Angry : (
Hi `Josh,
How many miles are on your 3.1 L ?
Has your trans ever been serviced ?
Has fluid & trans filter been changed ? If so, when ?
How high, what RPM do you have to `hit b-4 it kicks in ?
Could be debre clogging trans lines ?
Please post additional infor, so that our expert tech
members can help or give their possible solutions.
Good Luck
Old Mar 29, 2009 | 11:35 AM
joshtazz's Avatar
thier are 165,000 miles
dont know if its been serviced
my dad just changed the fluid and filter a month ago
it kicks in at about 4500 rpm after i hold it at that rpm for like 10 secs
thnx for the help
Old Mar 29, 2009 | 03:56 PM
joshtazz's Avatar
bump bump
Old Mar 29, 2009 | 04:14 PM
sounds like the common problems of the transmission which are torque converter / pressure solenoid, not a cheap fix if i'm right. You are better off probably getting a used transmission from morad or a junk yard and putting it in.
cali2000ss
Jul 3, 2009 05:59 AM
slinkeey
Feb 3, 2009 10:33 AM
bwerblo
Jun 6, 2008 06:10 PM
Yellow_Monte
Mar 1, 2007 01:35 AM
roadshoptuner
Apr 16, 2006 12:34 PM
