Tranny issue
Old May 22, 2009 | 08:32 PM
alabamamonte's Avatar
Default Tranny issue
So im driving down the highway the other day doing about 65 and I stomp it and the tranny/motor has a 2 second reaction time.... Almost like it stalled out of something... What could be the cause of this? its an 07 lt and I just rolled over 36000 miles... (of course)
also I copied this out of somebodies signature:
-Aluminum Transmission Pan w/
Cooling Fins and Drain Plug
what exactly is that and what does it do?
Old May 22, 2009 | 08:40 PM
The Popcorn King's Avatar
I'm not familiar with the 6th gens, but it almost sounds like your PCM is going into survival mode. It does that so you dont blow a hole in your tranny.
They replaced they trans pan with one that is aluminum ( it dissipates heat better) has cooling fins like this..
and has a drain plug so when you drop the pan, the oil doesn't splatter every where.
Old May 22, 2009 | 08:46 PM
By survival mode do you mean my tranny is about to go????
Old May 22, 2009 | 09:23 PM
just the opposite. it stall it a sec so it wont cause damage. But i know that a tune can fix that.
Old May 22, 2009 | 10:14 PM
biggriggs's Avatar
The finned aluminum pan is supposed to help keep the tranmission cooler by increasing the surface area of the pan (which holds the trans fluid).
The drain plug on it is a convenience feature.
Our transmission pans don't have any sort of drain plug like the oil pan does, so when you go to remove the pan you have to carefully spill the oil out.
Also, with a plug you could drain your transmission fluid without dropping the pan.
-Riggs.
Old May 22, 2009 | 10:15 PM
yea...what he said.
Old May 23, 2009 | 12:30 AM
biggriggs's Avatar
Sorry JJ, I never even read past the first post.
I didn't realize I was retyping what you originally said
-Riggs.
Old May 23, 2009 | 07:05 AM
Dont worry about it man. All that matters is that the OP gets the answers they are looking for.
jamie_marie
Mar 1, 2013 08:47 PM
Sbrunelli
Jan 21, 2013 08:41 PM
DenaliZO6
Oct 26, 2011 01:25 PM
Tdd8ball
Jul 25, 2011 07:24 PM
slinkeey
Feb 3, 2009 10:33 AM
