trac abs lights
Old Feb 21, 2010 | 11:50 PM
dupree155's Avatar
Default trac abs lights
I have a 2002 3.8 ss monte carlo and the trac off and abs lights come on soon as I shift it in drive..... can anyone tell me how to fix this problem thanks
Old Feb 22, 2010 | 12:05 AM
are you getting any check engine/trac control lights coming on??
Old Feb 22, 2010 | 08:41 AM
You'll have to check all the connections for the wheel hub assemblies on your car, most likely one of those have taken a crap on you.
If all the connections look okay, and you cleaned them and the problem still persists you'll have to get the ABS code read and find which hub assembly went faulty and have it replaced.
Doing it yourself ~$60-$100, paying a shop to do it will run you about $350
Old Feb 22, 2010 | 10:17 AM
monte07's Avatar
i was going to say the same thing blacksheep
Old Feb 22, 2010 | 06:17 PM
Enzo354's Avatar
STILL SLOW
Mines doing the same. What ever haha.
Old Feb 22, 2010 | 07:32 PM
i got teh 3400 with the same problem, mines the hub assembly im told.
Old Feb 22, 2010 | 09:50 PM
dupree155's Avatar
Ok thanks ill try that and see wat happens
Old Feb 23, 2010 | 08:33 AM
If you were told WHICH hub assembly, check the connections and clean them first before you pay to replace it.
teamfbody
34
Aug 11, 2013 08:22 PM
cbcain1978
Jun 19, 2013 03:47 AM
ladagosta
Aug 24, 2012 09:54 AM
Franks 03SS
Jun 1, 2012 08:10 AM
