Top swap (help needed)
Old Feb 28, 2014 | 08:48 AM
BrandonStebing's Avatar
^^agree
I have heads, all I need is the balancer now! I misread the add it came with heads I haven't even opened the box yet. But one last question this is what I have
-heads
-sc and lower intake
-fuel rails and injectors
-coil packs
-valve covers
-balancer (needed)
-3.8 pulley (need serpentine belt)
-I have full 3" exhaust with a magnaflow cat'd down pipe
-looking for headers
Other than all this and a good tune. What else do I NEED, and what else should I probably consider getting?
Future mods
- headers (unless I get them before the top swap)
- inter cooler and heat exchanger (zzp)
-er ratio rocker arms
- maybe bigger injectors
Old Feb 28, 2014 | 09:14 AM
turbo monte's Avatar
you will need some wiring harnesses to connect all the wiring, i think zzp sells the harnesses (not familiar with what it is you need but i read about it a long time ago)
Old Feb 28, 2014 | 10:19 AM
nitehawkjcb's Avatar
Something to scan your motor for KR.
Old Feb 28, 2014 | 12:23 PM
l67ss's Avatar
I have the harmonic balancer and the plugs for the injectors. Say $30+shipping?
Old Feb 28, 2014 | 10:54 PM
Enzo354's Avatar
STILL SLOW
You will need a new coil pack bracket off an l67, and the additional idler pulley and bracket.
2 Bar map sensor
The extensions for it
The Injector pigtails as stated before
The BBV on the supercharger if it doesn't come with it.
Throttle body and matching MAF
BrandonStebing
Mar 13, 2014 08:49 AM
Gabe Ryan
Feb 13, 2014 06:56 AM
LW57912
Mar 7, 2013 02:48 PM
Overdose666
Feb 6, 2013 12:40 AM
my00monte
33
Apr 4, 2011 06:37 AM
