Top swap (help needed)
Old Feb 25, 2014 | 03:33 PM
BrandonStebing's Avatar
Default Top swap (help needed)
I have a 2000 Monte Carlo SS with an n/a 3800 series 2. I am looking to do a top swap. I payed 300$ for everything but heads, headers, l67 harmonic balancer, rocker bolts, serpentine belts, and gaskets from an l67 motor. Now who can tell me what else I need to get this top swap done completely, other than the oblivious gaskets, PCM tune, belts. My list of current mods include: a full cat back 3" exhaust, and a magnaflow cat and down pipe, and a short ram air intake, new plugs wires thermostat, and new colant level temp and other sensors. I have read a lot about this subject and know a little bit about everything needed for a top swap. I know there is somethings I need to do to my axels, and my tranny. I just need some help putting things together with what I know and what I don't. Any help is appreciated. I need to know everything I will need, new or just to get rebuilt. I've been thinking about headers, cam, new pistons, er rocker arms, ECT. I just need to know what I HAVE to have before I start tearing into my monte.
Old Feb 26, 2014 | 08:56 AM
z34phoenix's Avatar
well like you said:
-Heads
-balancer
-bolts, belts, gaskets
I assume you have:
-fuel rails
-injectors
-SC
-lower intake manifold
-TB
-coil bracket with pulley and tensioner
-stand off pulley
-Headers are basically a requirement if you plan to run the 3.8" pulley on the blower.
-trans and axles will be fine if you have the pcm adjusted for the trans you have.
Old Feb 26, 2014 | 10:17 AM
Originally Posted by z34phoenix
well like you said:
-Heads
-balancer
I assume you have:
-fuel rails
-injectors
-SC
-TB
-stand off pulley
Would I be fine running my stock heads?
Old Feb 26, 2014 | 10:29 AM
You can't run your L36 heads on a top-swap. The injectors would have no where to go.
Old Feb 27, 2014 | 07:30 PM
Do you know of anyone on the forum selling supercharged heads, and a harmonic balancer, or a site where I could get them for a good price.
Old Feb 27, 2014 | 08:11 PM
turbo monte's Avatar
Search grand prix forums and join up and post in there wanted ads that your looking for a set. Also check junk yards. Why didn't you get the heads off the engine you got these other parts from?
You should be able to find them cheap but shipping is a killer. Last time I shipped heads it costed me like $85!
Old Feb 27, 2014 | 09:24 PM
l67ss's Avatar
I have an l67 balancer
Old Feb 27, 2014 | 09:25 PM
l67ss's Avatar
Could also get heads for $100 plus shipping
Old Feb 27, 2014 | 10:58 PM
Enzo354's Avatar
STILL SLOW
Just sell it all and save yourself the hassle. Put it all towards a turbo kit.
Old Feb 28, 2014 | 07:31 AM
^^agree
