Top swap
Old Jul 20, 2009 | 06:51 PM
Enzo354's Avatar
STILL SLOW
Default Top swap
I want to do a l36 to l67 top swap, and mabye we can sticky it because Im sure alot of people would like to know all the parts needed for this.
Im gonna use 2 kits, are there any other parts needed???
https://www.zzperformance.com/grand_...=382&catid=109
http://cgi.ebay.com/ebaymotors/3800-...Q5fAccessories
List so far (anything im missing?? and will these kits work together?)
* heads
* valve covers
* lower intake manifold
* injectors
* fuel rail
* supercharger
* TB (no maf)
* vac lines
* idler pullies
* brackets
* balancer
* Garlock supercharger gasket
* Instructions on paper and CD
* L67 brake booster vacuum line
* Idler pulley with custom standoff, bolt and washer
* Throttle body gasket
* Accessory belt (95.5" for '99+ with 3.8-4.2" pulley)
* Autolite 103 plugs
* Supercharger oil
* Supercharger bolts
* PCM reprogramming
Old Jul 20, 2009 | 07:37 PM
03Monte's Avatar
Dont buy from ebay, i would call morad directly! (they may give you a discount, because they will save seller fee's)
also, i don't see torque to yield bolts on there, or any other gaskets but SC/TB.
Old Jul 20, 2009 | 08:23 PM
Enzo354's Avatar
STILL SLOW
Well it says supercharger bolts so im not sure on that, and what other gaskets are needed?
Old Jul 20, 2009 | 09:57 PM
nemesis's Avatar
2009 Monte Of The Year
here you go:
http://www.grandprixforums.net/f17/t...lots-7763.html
i will have fuel rail, ported blower, 3.8 pulley, and other misc parts for sale after this weekend if you interest.
Old Jul 20, 2009 | 10:18 PM
Enzo354's Avatar
STILL SLOW
Thanks for the link, and ill shoot ya a pm.
Old Jul 20, 2009 | 11:18 PM
03Monte's Avatar
well, i don't see head, valve cover, or intake.
Old Jul 21, 2009 | 01:13 AM
sprfrk2005's Avatar
i cant be wrong but i dont think u need the zzp kit u would be better off just buying everything apart IMO i ordered my parts from morad they will be here tomorrow and i have pretty much everything i believe, o0o dont forget the harness upgrade will also be needed
Old Jul 21, 2009 | 08:14 AM
Personally I prefer the GM s/c gasket over the garlock. For some reason that garlock material seems to like to soak up oil and such from the pcv, moreso than the stock gasket. Maybe its just the ones I've seen...
Old Jul 21, 2009 | 10:18 PM
Enzo354's Avatar
STILL SLOW
Thanks for info guys.
sickofsoyo
Mar 10, 2009 10:24 PM
sprfrk2005
22
May 22, 2008 01:25 PM
vita
Mar 11, 2008 11:49 AM
1999L36
Dec 15, 2007 10:47 AM
Cowboy6622
Dec 15, 2007 10:40 AM
