Timing
Old Nov 10, 2013 | 01:31 PM
julie7088's Avatar
Smile Timing
How to check the timing on a 2005 Monte Carlos V6 3400?
my car does not want to start. It sounds like it's turning but doesn't completely rollover. When I am stopped at a red light it dies on me. I have 104000 miles on it I have had my spark plugs and wires changed and that did not help. I have put in STP twice and tonight when I filled up I put in another treatment that will help evaporate water. Hopefully that will help.
Old Nov 10, 2013 | 06:36 PM
Julie:
What seems to be the issue your having with it that you suspect its a timing issue? Maybe its possibly a crank sensor? Does it start run? does it run poorly? Or doesn't it start at all?
Old Nov 10, 2013 | 07:36 PM
These cars have computer controlled timing. Nothing to adjust. These cars do not have anything to mechanically adjust.
If timing is off, there is a problem and it's not an adjustment.
What is the situation prompting your to want to check/adjust the timing.
Dam20735
May 23, 2013 04:09 PM
fedspunisher
Nov 12, 2006 06:52 PM
jogasz28
Jul 20, 2006 03:28 PM
tiny4lx
May 16, 2006 06:55 PM
Cainius
Jan 16, 2006 02:02 AM
