Th350
Old May 7, 2012 | 10:06 AM
Camaro978's Avatar
Default Th350
Hi I'm planning on buying a 4th gen monte and put a 1969 350 small block from a corvette into it with a TH350 and was wondering where I can buy the mounts and if I would have any fitment issues. Thanks.
Old May 7, 2012 | 10:26 AM
Budsjlm's Avatar
what mounts are you looking for?
Motor mounts if it a v8 stock mounts will work, v6 you will need to move the motor mounts on the frame
if i am not mistaken a th350 short tail will fit right in place of the TH200
not sure if it will with a 2004r
if you need a new crossmember i do belive jegs, summit ect makes crossmembers for 4th gen's and then you have provisions to run true dual exhaust
etvalentin
Jan 16, 2013 08:05 AM
crankshaft3rd@yahoo.com
Feb 24, 2012 05:32 PM
JoeNH3
Nov 26, 2011 02:56 AM
bubba1228
Apr 21, 2009 07:38 PM
