Supercharger for 00 SS
Old Apr 5, 2008 | 07:14 PM
Buck's Avatar
Default Supercharger for 00 SS
This may sound like a dumb question, but will a supercharger off of a Buick Park Avenue work on my 00 Monte Carlo SS, with the 3.8 L. If so what will i have to do to it to make it work. If not , what will work?
Old Apr 5, 2008 | 09:02 PM
Default RE: Supercharger for 00 SS
You really only need to post the topic in one section- not repeat post in other sections. It just takes some time to get a response.
On to your question- yes it will work, but it is a TON of work to put it on. If your mechanical skills consist of being able to do oil changes and spark plug changes, then I wouldn't even consider doing it. You end up having to strip the engine all the way down to the short block (ie you can see the pistons and block)- and you have to pull the crank balancer (it requires a special puller and the bolt is a nightmare to get off).
Here are most of the parts you'll need:
[*]L67 Heads (Pair)[*]L67 Fuel Rails[*]L67 Fuel Injectors[*]L67 Pullies (2 idlers and one crank)[*]L67 Supercharger and throttle body [*]L67 MAP sensor and MAP sensor bracket
L67 Lower Intake Manifold
L67 Valve Covers (pair)[*]L67 Coil Bracket
All necessary vacuum line, bolts, and accessories for the job
Plus you'll need all these gaskets/bolts:
[*]Head Gaskets (2)[*]Crank Bolt (stock bolt is torque to yield)[*]Supercharger Gasket[*]Throttle Body Gasket[*]Valve Cover Gaskets[*]Fuel Injector O-Rings[*]DHP PCM with proper gear ratio calculated[*]Head Bolts[*]Lower Intake Gaskets[*]Supercharger belt
That list should cover most of what you need. Basically you do almost all the work for a complete engine swap without actually pulling the engine/trans.
Old Apr 5, 2008 | 11:09 PM
Buck's Avatar
Thanks, sounds like a job for a mechanic, eh.
Old Apr 6, 2008 | 12:49 AM
rysZ34's Avatar
Not to mention, lower compression pistons if you want to do all of that work. L67's (supercharged) compression ratio is 8.5:1 and an L36's (naturally aspirated) comp ratio is 9.5:1. Z34 phoenix just added a s/c to his originally naturally aspirated 3800 without replacing heads/gaskets/valve covers. He replied in your other thread.
Old Apr 7, 2008 | 06:50 AM
z34phoenix's Avatar
nope never did anything to that GTP... made a ported blower for it... but sold the project. swaping the pistons isnt a good idea.... with tuning the higher compression will give more power. and for the time and cost to swap pistons, its better to swap the entire engine with a l67.
Old Apr 9, 2008 | 07:56 AM
ORIGINAL: rysZ34
That would be shooting yourself in the foot. Assuming you do a few basic bolt ons at the same time to keep the car from knocking- you'll make more power on the higher compression pistons he already has. Many of the high dynoing supercharged cars run an L36 bottom end/pistons. Also, L36 compression ratio is 9.4:1.
marcello7x
Dec 16, 2006 02:41 PM
dickie34
May 4, 2006 10:05 PM
mcarloss04
Apr 29, 2006 02:10 AM
96MonteCarloSS
Nov 15, 2005 08:25 PM
mcarloss04
Sep 25, 2005 01:09 AM
