supercharger
Old Feb 20, 2006 | 06:15 PM
mcarloss04's Avatar
Default supercharger
What would be the best supercharger for an 04 monte carlo ss non s\c for the stock transmission
Old Feb 20, 2006 | 10:56 PM
maclawa's Avatar
Default RE: supercharger
m90 eaton supercharger my friend
but do you know how much modding you need to do for it to fit ur L36 engine? I'm in the process right now and its a beatch
Old Feb 20, 2006 | 11:35 PM
mcarloss04's Avatar
Default how much modding
How much modding is that and what does it include
Old Feb 21, 2006 | 07:40 PM
maclawa's Avatar
Default RE: how much modding
ok well, first u need to get the supercharger, L67 heads for your L36 engine, L67 Throttle Body or high flow throttle body for your L36, Fuel rails and injectors from an L67, Compression ratio needs to be changed, and computer chip needs to be modified as well to support the compression change and air fuel crap. as well you'll need to do your air intake. if you go above 300 whp you need to change your transmission or upgrade to stronger diff and all that other stuff you can find on ZZP's website. intercooling as well is an option.
anyone else want to make suggestions as well please do so.
I know before I put all this in my car I'm doing Ubend delete/ larger downpipe / high flow cat / performance muffs as well.
its alot of crap. haha
Old Apr 18, 2006 | 05:52 AM
CMC's Avatar
CMC
Stage 1 CSC kit, sold through ZZP and Stattama.
And if your not keen on the centrifugal setup, ZZP also has their M90ASS kit.
Just take a look over at zzperformance.com
Old Apr 29, 2006 | 02:10 AM
z34phoenix's Avatar
i personally like the m90 retro fit kit. cause that leaves plenty of upgrade space later. cause the fastest Wbody cars are running an M90 and a turbo together!! if you get a CSC you will have problems fitting a turbo. not that the adverage person will do a SC and a Turbo, but i dont like to limit myself for furture mods. i also like the m90 cause there pulleys are easyer to find if you want to down size the pulley to make more boost!
marcello7x
Dec 16, 2006 02:41 PM
DiCrazy
May 10, 2006 02:47 PM
dickie34
May 4, 2006 10:05 PM
96MonteCarloSS
Nov 15, 2005 08:25 PM
mcarloss04
Sep 25, 2005 01:09 AM
