Strange Whine
Old Aug 16, 2010 | 07:38 AM
Absolutpolack's Avatar
Default Strange Whine
Ive been having some troubles in my engine with noises recently. I had a metallic grinding noise and heavy heavy whining under acceleration which I diagnosed to my AC compressor being shot. Did a AC delete and got rid of the condenser as well. That solved my metallic grinding noise and a little of the whining. It was actually completely silent during my test run and for the first 45 minutes of my commute. Pulling into work and during the last 15 minutes of offramp/city road travel I notice that its whining alot. Its a low whining, doenst sound the the PS sounds I had in my Jeep before I replaced the PS pump and its not affected by turning and is barely affected by speed. However when idling it becomes intermittant. When driving, its LOUD.
My drive belt had cracks and normal wear, nothing bad, although I know its probably been about 45k since replacement, ive put 24k on it since i bought it last June without replacing it. Is there any way to test the water pump or alternator to see if its the whining? When I had the belt off yesterday I spun the pulleys and they all sounded fine.
Old Aug 16, 2010 | 07:47 AM
MAMONTE's Avatar
Hmmmmm.
Check the power steering fluid, it could just be low on PS fluid. Or the PS pump could be bad, its common on these cars.
The alternator bearing could be going out too.
Try putting some belt dressing on your belt, and see what that does. If your belt is causing the noise, belt dressing should quiet the whine and help you determine you need a new belt.
Old Aug 16, 2010 | 07:37 PM
PS was a little low but that wasnt the noise. When I looked at it closely after work, I saw that the water pump pulley was wobbling. Uh oh. Gonna replace that tomorrow and hope that its the final problem i have.
Old Aug 16, 2010 | 08:00 PM
monte07's Avatar
the usual wines come from the belt the belt tensioner the ideler pully after that is the water pump altenator power steering. it is od that the ac pump goes bad from gm. i am sorry that you took off your ac pump and every thing. just to find out it was the water pump. if you deside to put the ac pump back on gm is netorius to use the synthetic r134. i am glad that you found the problem
kweef
Jan 6, 2009 11:35 AM
mrl390
Dec 2, 2007 12:19 AM
cain45
Aug 20, 2007 08:57 AM
SoCalSS
Aug 18, 2005 12:45 PM
SoCalSS
Aug 13, 2005 04:51 PM
