Starting problems 2001 ss
This car will puff back or hiccup also on occasion then stall , there is no trouble codes and runs great once started. I am going to check fuel pressure and post thanx to all u mc forum guys for helping me out........
I just checked fuel pressure at the port on the regulator, was 40 psi. with key on motor off held for 5 min. and strted to drop went to 40psi. in ten min. With motor running pressure was at 46 psi. I took vacum hose off of regulator and pressure shot up to 56 psi.????? I also unplugged maf before pressure test and car was still hard to start made no difference.....
I have a 2001 ss 3.8 with 70,000 mi. car starts on first cold start and runs good . after car is at operating temp and is shut off it will take several attempts to restart once it restarts runs fine? I have had this car for only a few months and like it alot, want to fix this problem anyone have any advice before i start changing un needed parts, there is no engine service soon light coming on....... Thanx
6th Gen ('00-'05): 2001 starting/bcm problems?
jim1405
Oct 10, 2023 10:14 AM
hank635
Jun 14, 2010 02:30 PM
